stop same posts from repeating in different blocks
in the attached picture you can see my posts in the first top block is again being repeated in the block under it. how do I prevent this and instead have the block below display other posts. want the newer posts in the first block and older posts moving to the block below it
https://imgur.com/1Evd67z
Hello !
Edit your page using tagDiv composer: https://www.screencast.com/t/O99pQMhLT ; Click on any block and go to Filters: https://www.screencast.com/t/F3Dt6SnjyomZ Set your filters as you can see there so your posts won’t be repeated.
both blocks are for same category. how do I get some of the posts to be in the top block and other posts(no repetition) in block below it whiles they have the same category
Hello !
You can achieve that by using the post offset option. If you have 4 posts on your first block, then you will need to set on your second block the offset option on 4: https://www.screencast.com/t/M4IcRZJriCZZ
