Hi, we are seeing a very strange glitch with our top menu with logo on http://www.fokus.ba.
When site loads, it is shown for a second, thank full black, nothing visible on it. If we scroll a bit down, and than up, it shows as it is supposed to be.
I guess it is some plugin (as always), but we are really low on plugins at this moment, so if someone could took a look at this, we will really appreciate this – to learn what is causing this and how to fix it 🙂
I also suspect a plugin, but only you can find out which one causing this issue. Please disable all the plugins except of Visual Composer, clear cache and see if the issue persist. If the issue is gone, try to active your plugins one by one and see which one cause this issue.
It happens sometimes also on windows chrome or firefox, you have javascript error in the console(usually this comes from plugins that conflict with the theme javascript) – http://screencast.com/t/2bmM3IrndSx also the newspaper font is not found. So please make sure that you update the theme properly, you can try to upload the theme again maybe it was an issue when you updated the theme. Let me know how it goes!
