Stretch row does not work as it should
Background color does not fit the line -> http://imgur.com/a/7pWfI
I do not want to extend the content, just the background.
Please try and deactivate the tagDiv Composer editor from the plugin section, and see if the issue is fixed. However you should try and recreate your page with the new featured composer. Do not use both the editors at the same time, this could provide unexpected results.
