Structured Data problem
For some time, webmaster tools have been reporting structured data errors. How do I set the template to fix the problem? Thank you
Please specify what are the reported errors you are receiving. The default theme provides no such errors. Test again and provide the results and the errors. If you use a plugin that could be affecting the results, deactivate it and test again.
Hi SImion, in the hentry (Markup: microformats.org) i have 3440 error author and entry-title
I have tested some of your posts in the Google structured data testing tool, there are no issues present
https://www.screencast.com/t/RBzRzGaXOUom
https://www.screencast.com/t/lPkipKe5bA
If there were errors they would appear in the test tool. The theme is tested and does not provide any errors in this matter, so there should not be any problems.
