So I was looking at my webconsole and found that I had some issues in my structured data
Structured Data > hentry (markup: microformats.org) (Missing: updated)
So I looked around and found that Yoast has something to do with this. However, they recommend to contact you guys?
https://kb.yoast.com/kb/fixing-hcard-author-error/
Missing: updated / entry-title / other
The requested tag is not present in your theme or is incomplete. Please contact your theme developer for assistance.
Please advise for a fix. They did have an option to remove hentry by adding a code to the functions.php but I’m not sure if that is the way to go.
Please advise and thank you.
Can I PM you the URL?
But first, you think that updating the theme will fix this?
I was not aware Newspaper 9 is out.
I’m on 8.8.2 .
Things move fast with you guys! Good stuff!
The latest version of the theme is NP 9.0.1. If you want to send a private message you should send it to contact@tagdiv.com.
