It seems there is an issue with Custom Post Types and Style 8. Everything else seems to work as intended, but when we try and use that specific style with a custom post type it just does not display the image. It works on regular posts.
Any help would be amazing
Those templates that come with the theme were created for posts, they will not work with custom post type. For custom post type you have to create a template, you can use structure present in the post template 8. Just check the code structure inside the template files single_template_8.php and loop-single-8.php and check the official documentation – https://codex.wordpress.org/Post_Types#Custom_Post_Type_Templates
The style 8 works exactly like the homepage block so I guess you will need more customization – http://screencast.com/t/U6ReMU1BSt
