We are working to change the theme on a site with over 8,500 posts where the last update of the current theme was made 4 years ago. For this reason we wanted to do a detailed test of the theme change. We cloned the site on a local environment and made the necessary adjustments. After that we set up a staging environment in which the client can see the changes before making the change on the live site.
Everything is fine except for a style difference for the title and category on the home page in TagDiv Composer. All settings are the same, but the difference persists and we can’t find the cause. Can you help us, please?
local
https://imgur.com/NJdFol9
staging
https://imgur.com/948LU4g
You need to use the inspector to see the font family that is use on staging and localhost, I think that are loading different styles. For this make sure that you have enable the Google fonts in theme panel https://i.imgur.com/itlyuFH.png or you gave loaded the font in theme -> https://i.imgur.com/CojWvOP.png
Hope this will help you!
