See this comment section: https://www.fuckdiestudieschuld.nl/meerdere-schulden/#comment-87
I would like to fix two things:
#1 The yellow line below ‘bewerken’ (Dutch for edit) is correct, the yellow line below the date is placed a bit too high. I have no idea why. Any thoughts?
#2 I would like to change the styling of the links in the comment meta stuff (date + edit) but NOT in the comment itself. How can I address only the date + edit thingys with CSS?
Thank you! 🙂
Maaike
Hi! Thanks for your reply. I’ll try and explain both points better.
#1 See the two blue arrows on the image. Those two yellow lines should be aligned, right? They are not. (Also, the yellow line should start a bit below the letters, like with the second blue arrow. The yellow line below the date is a bit off.)
Image = https://ibb.co/cNTbb46
Site = https://www.fuckdiestudieschuld.nl/studieschuld-aflossen-is-leuker-dan-verwacht/
#2 Problem #1 is not important anymore if we manage to fix problem #2.
What I would like =
– The date and edit link should be black, also when hovered. No yellow line, no red, just all plain black.
– Links in the body text should be yellow, just as the links in the regular body text of the posts.
I can change the styling of the links in the comment section, but then both change at the same time. Can I somehow address them separately with CSS?
I hope you understand what I’m trying to explain. 🙂
Maaike
Hello !
This should be achievable but we need wp-admin login in order to see all the buttons.
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
