Hello Support-Team,
I have a somewhat special question. I am looking for a possibility to style posts within the Flex Block 1 differently based on the category they are in. Currently they are looking like this for all posts: https://imgur.com/a/2aDSHVK
Now I am trying to add maybe a background color or a font color to these posts but only if a certain post is in a given category. This would result in posts looking different. What would your advice be for this issue?
Best regards,
Tim
If I correctly understand, you want to make a post to be particularly displayed, unfortunately, the setting form our theme are apply on the block for all the posts that are displayed in it.
What you want maybe it can be done with some custom css, but this depends on what situation you want to apply the css, if is about applying on posts from specific categories, then I think it can be done a code for it.
