hi
i start to work with your theme in Hebrew language(RTL)
and i can’t make the sub menu to align to right so it will popup exactly below to menu item.
(i want that the first letter of the sub-menu item will be in one line with the first letter of the category menu item)
i don’t have website to show yet so i try to do my best to explain the issue.
it will be match easier if it was passable to upload a screenshot…
thank you
Haim C
Please use this custom css in Theme Panel > Custom css: http://screencast.com/t/pxrZiGw0e
.sf-menu li:hover ul, .sf-menu li.sfHover ul {
right: 0;
left:auto!important;
Result: http://screencast.com/t/nby9qykVX2I
Hope this helps!
Unfortunately we recently have decided that starting with the next theme update we will not include rtl support within the theme. You can still use the theme as it is but unfortunately you cannot updated it as you will lose the rtl support or you can update it and make yourself the necessary adjustments needed.
Sorry for the inconvenience!
Thanks for the message and for understanding!
i am sorry but i can’t understand this kind of move.
while all the rest theme companies add support to RTL, your company remove!
what about all your clients that there website use your theme in Hebrew and Arabic language.
i only bought your theme last week so i spend only few days to build my site with your theme,
but now that you tell me that you going to remove the support i will stop! and find me a new theme
that support RTL.
your theme i useless for me if i wont my website will be update for a lot of years.
how can i get refund for my Purchase????
Please contact us via email contact@tagdiv.com and specifying in your message that you want a refund. Sorry for inconvenience!
