I’m having an issue with the subcategories on my website: https://naturezaviva.blog
I’m using the Magazine PRO theme.
When I click on a category, the posts are displayed normally.
However, when I click on the subcategories, it shows:
**There are no posts to display.**
Note that there is a post in this subcategory.
When clicking on the name Desmatamento (red arrow),
it shows that there are no posts there.
While editing the post, I configured it as follows:
Check the filter of the block.
Let the offset field be empty with no space or value, and see the results: https://prnt.sc/26SoUFv7QzxG -> https://www.screencast.com/t/peVbVmUDE.
Make sure you use that category as the primary category.
Thank you so much for resolving the issue.
I truly appreciate your support!
