Subcategories posts in Posts Loop
Hi guys,
While working with the “posts loop” block, I realized that it only lists the posts from the main category and doesn’t display the posts from the subcategories of the parent category. This limitation negatively impacts the organization of information. Additionally, the Post Loops block is the only one that displays advertisements in the middle of the post lists. Therefore, I strongly suggest an update for the “posts loop” block to include both the category and subcategory posts.
I kindly request that you consider this suggestion for future updates. It would greatly enhance the functionality and organization of the “posts loop” block. Could you please let me know if and when this improvement can be implemented?
David
I will add this request, but I don’t know if it will be implemented.
