Hi, is it possible to create links to posts under submenus?
Like this site: http://thesmartlocal.com/
I’m trying to get something like the “Top destinations”, “Editor’s choice” headers, and manual links to posts under those headers.
Is that possible?
Hello jasonleewkd,
Yes, it is possible if you will use the Custom links from the Settings in Menus area from WordPress. More information about this case might be found here -> https://easywpguide.com/wordpress-manual/appearance/updating-the-menu/adding-a-custom-link-menu-item/
Thank you for the suggestion. However, I’m looking to do a sub-menu similar to Part C of https://forum.tagdiv.com/menus-newsmag/.
I.e. have the equivalent of “Top destinations”, “editor’s choice” etc with manual links to post below it.
Hello jasonleewkd,
If you want to achieve menu like the Travel Menu, you should follow the following topic from here -> https://forum.tagdiv.com/topic/create-main-menu-default-themes/
