Hi, the theme works fine, but i would need to improve performance. On Newspaper system status i see two problems:
“Speed Booster v4.4 – Disabled – incompatible plugin detected: woocommerce-mercadopago/woocommerce-mercadopago.php”
“Caching plugin No caching plugin detected – for best performance we recommend using WP Super Cache”
I´m running the last wordpress version on multisite mode with supercache plugin enabled to network. I dont know why Newspaper dont detect it. Also, what change i must to do on woocommerce-mercadopago.php to solve incompatibility.
Many thanks for your help. Regards,
Alex
Hello akalki,
The speed booster is an optional plugin and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that they add many plugins and some of the them are not written fine so the developer took this decision. If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
Please notice that our theme is not tested with multisite mode (plugins) and we cannot recommend using this type of plugins with our theme because its were not made any tests in this regard. Please try to use our theme only with tested plugins for better results.
