System Fonts
Hi team,
My ad company (Mediavine) says I should use system fonts with my theme to make it fast for Web Core Vitals. When I turn off Google fonts in Newspaper theme, my speed shot up by at more than 10 points on both mobile and desktop. So, if I keep Google fonts turned off, which fonts should I use with the theme for the fastest performance?
Currently, my H1,H2 seems to be defaulting to Times New Roman but it looks terrible. I like Oswald but it slows down my site. Suggestions?
Hello !
In this case you can try this option from Theme panel – Theme fonts: https://www.screencast.com/t/hOvPdUYDHG Also I would recommend to look for the most efficient fonts and see which one you like.
Hello, I’ve tried some different ones. Can you tell me which ones are ‘system fonts stacks’?
The theme comes with two preset default Google Fonts: Open Sans and Roboto.
