Tabbed Content Scroll problem
I use the Tabbed , but everytime I click the tab and scroll down, the page always pull up back to the tabbed section. Any solution for this ?
Please provide your site url so I can have a closer look at this issue and get back to you with a more accurate answer.
my site is http://kriminalitas.com
it’s below the slider
if I click the “terkini” section, scroll down… it keeps pulling my browser up
thank you
This is a known issue and we do our best to find a fix for it. Theme developers will continue to investigate this and when they will find a fix for this issue I will update this topic.
Sorry for any inconveniences and thanks for your understanding!
do you have any suggestions what is the alternative for tabs? or at least I want to have that 2 parts (terpopuler & terkini) on a 2/3 section
The theme don’t have any element similar with tabs but you can use try to use two blocks on 1/3 rows like here: http://screencast.com/t/08Q3rIQhSIh – http://screencast.com/t/kBiFdJNQrVjm
Let me know how it goes and if this is not what you mean please provide more details about what you’re trying to do.
I can’t use that setup because my block setup is like this http://www.screencast.com/t/LqJxel4L
can I use the one that “related article – more from author” from the post page tab style on the homepage ?
http://www.screencast.com/t/4HVfI0Kzu
Related article tabs have a similar functionality as tabs built in from Visual Composer but unfortunately this part is not available in Visual Composer at the moment. We don’t have a shortcode for this element so it can’t be used on page like others blocks.
I do some browsing, I found some javascipt sourcecode.
I try that sourcecode and it seems the ‘fighting scroll’ problem fixed.
It remove the loading ‘effect’ though, but it fix the ‘fighting scroll’ problem.
So… problem fix… thanks Andrei
