Tabs problem
Hello everyone,
I have a problem with the element tab Newspapper.
Indeed I added two with two different text.
http://www.hostingpics.net/viewer.php?id=590762tabs1.png
However both seem active.
http://www.hostingpics.net/viewer.php?id=333888tabs2.png
Any ideas?
Sorry for my english and thank you in advance!
I also tested this with latest theme version(4.6.3) and Visual Composer plugin(4.4.4) and did not found any issues – http://screencast.com/t/mnNKUuvUwF – http://screencast.com/t/h3cweb2Nbg2K
Please check this without any plugins active leave just Visual Composer active, clear cache and see if you still have this issue.
Also provide a link so we can take a look.
You talk about the WPBakery Visual Composer plugin ?
Because when i want to upgrade to the latest version it ask me to enter a CodeCanyon Visual Composer license key. But i didn’t have that.
http://bm-integrateur.com/uvb/monde-des-bouchers/bouchers-francais/hugo-desnoyer/
I use the element tab at the end of the page.
Thx
You can find Visual Composer plugin in the theme’s files that you have downloaded from themeforest in /plugins folder. The latest version provided and tested with the theme is 4.4.4 version. Update it using this guide – https://forum.tagdiv.com/update-the-visual-composer-plugin-wpbakery/
Like I said above check this also without any plugins active, leave just Visual Composer active, empty cache and see if you still have this issue.
