Greetings,
I recently purchased your theme and I’m already facing some issues with setting it up.
I want to add tabs in my frontpage but I can’t seem to get them to work and there is no extra info in your documentation on how to proceed.
These are the screenshots:
https://dl.dropboxusercontent.com/u/28352937/tabs-back-end.jpg
https://dl.dropboxusercontent.com/u/28352937/tabs-homepage.jpg
As you can see, even though the tabs are created and I can see their titles in their homepage, there is no content in them (I have a Block 1 in each one of the tabs with a specific category to draw articles from).
This should be simple to set as you just need to place the content into the tabs, like this: http://screencast.com/t/3hqPZRugLmU and the result: http://screencast.com/t/NWv0ok7gd
As you can see I have also tested this and found no issues with this so please make sure that your are not using any plugins that may affect this and to do so try this without any plugins active and also empty your cache and purge files if you use any CDN host services.
I have made my tested with the latest theme version so if you are not using it I suggest to update your theme to the latest version which is 1.2 the check for this again and let me know of what you find and also provide your site’s URL so I can inspect this.
Hope this helps!
