I just bought this theme,
I had instaled the the plugin tagdiv composer , but TadDiv composer does not load
help me please
Thanks =)
Hello albertoaqui,
Make sure that you are using the latest version of the theme installed via FTP way, remove all of the untested plugins, clear all the caches and check the results. The plugin has been tested with the theme and works as expected.
