TadDiv Opt-in Builder Locker Problem in Post Settings for Lock Content CheckBox
I have seen that there is a problem with under post setting. There is a Locker Tab. Under the Locker tab there are three options,
1> Lock Content
2> Locker
3> Unlock Cost
In the First option Lock Content, i am not able to tick on checkbox. it is not visible to checked or not. IF i click at once there is not marked but it applied on website and that post will be locked but i cannot see in the Lock Content Check Box that it is checked or not. I think there are some problems from your side.
Please help me out from this problem.
Thanking You…
Can you please make a test using only tagDiv plugins? From your details it’s like something is interfering with the Opt-in Builder and most of the time this is when you have a plugin conflict (or when a child theme is used and the code from it is interfering, in case you have child theme, please set the main theme for a test).
I am not using child theme, I am using your Newspaper Theme Version 12.7.1 even though I have uninstalled Opt-in Builder Plugin and installed it again, but it doesn’t work. I have also found that these problems occur in Tag Div Composer. When I click on checkbox it does not appear that I have checked it. If Plugin problems occur as you said, then why it happens in Tag Div Composer same.
and what for Indian Currency Symbol – It is not working, it shows different Symbol like “P”
Please help me to do so I can work properly for my website.
If the problem persist when you are using only tagDiv plugins, then please make a full backup for the website and contact us via email at contact@tagdiv.com, provide temporary wp-admin and cPanel access and a link to this topic.
We’ll check it out as soon as possible.
