Tag div composer does not appear on template – or will not save work
When trying to set up a blank footer template, there is no option to use the tag div composer. Or if it does appear, it will not save any work, or says content not created by tag div composer. Already deleted tag div composer and reinstalled, and shut off most plugins, did not help. Tag div composer did work at first. Have been at this for days for a fairly simple setup.
Hope you can help
Thank you
Greg
The footer cloud template can be edited, but it must be set on a page or cloud template in order to be able to edit it, this was the way made by our developers, normal we all think that it should work as a normal template, but is look that the footer template has some elements that can be edited only when it is assigned on a page or cloud. This is the only way that it can be edited after you download it from cloud library.
Also now all cloud templates can be edited and assigned using the frontend and using this method is more ease to use the method for editing the footer template.
Thank you. 🙂
