tagDiv Composer and WP Statistics have problem.
Hello
I just noticed that the tagDiv Composer does not work with new Version 12.1.0 of WP Statistics.
Regards
The theme and provided plugins are tested with these plugins
– https://www.screencast.com/t/XWrI4GkVD
Anything else or any other plugin may as well work properly, or simply be incompatible. Maybe it is a setting in the plugin you mention, you could check that and make some tests. If there is still a problem, unfortunately there is no solution to provide in this case.
We cannot test the theme and composer with all the plugins.
