Tagdiv Composer causing issue with Yoast SEO plugin
Hi Andrea_Menghini and giriraj, for me wit Newspaper v11 and Yoast SEO v16.7 everything seems to work normally -> https://i.imgur.com/OgduTIa.png -> https://i.imgur.com/wBBHESX.jpg
I have one suggestion, please disable all plugins except Yoast SEO, after that delete tagDiv plugins and reinstall theme from Newspaper > plugins, then please make a new test to see if the problem is persisting (this test need to be done with the parent theme and only with tagDiv plugins and Yoast SEO plugin enabled)
Let me know the results!
If there are still problems, please make a full backup and contact us at contact@tagdiv.com provide all details and screenshots you can, also provide wp-admin and cPanel access and include the link of this topic in mail.
The pictures you just posted doesn’t have any relation with our problem.
Yoast Seo doesn’t work when we are WRITING AN ARTICLE, doesn’t change when we insert a link or picture, and doesn’t work anymore the words counter.
It seems this theme is not fully compatible with Yoast SEO.
I’ll try anyway you’re advice, let’s see.
I just follow your suggestion but doesn’t change, the problems are still there.
Yoast Seo is not reactive when (WRITING AN ARTICLE) I insert (or delete) a link or a picture and doesn’t count the words… every times need a refresh, but after max 5 minutes the problem show up again.
The conflict is definitively with the theme (no others plug-in, except Yoast and Theme plug-in, are installed).
Hello Calin,
As Andrea_Menghini mentioned, the screenshots are in no way related to the reported issue.
If we edited an existing article or created an article, the green status is changing to orange.
Especially Internal and External links (SEO), Readability will be changed.
so again we have to refresh the screen, and then it will back to green. Even if we did a small edit in the article, the status is changing to orange.
Once I saved the article with green status, then it’s fine.
You can see this –> https://www.screencast.com/t/zkPozRB6
If I refresh, the above internal and external links will be changed to green.
You may check with an article.
Giri
Hi giriraj and Andrea_Menghini, it seems that I miss understand the problem, I was thinking that you are referring to an old bug between Composer and Yoast when adding blocks.
Now I understand what the problem is and indeed it seems that some of elements are not update correctly and only after the post is publish or updated, from my test this is the normal results and after publish I got this -> https://i.imgur.com/Lvkxkkp.png
→ https://i.imgur.com/YvNLlLi.png
I announce a developer about this satiation and he said that this will be checked and fixed as soon as possible, also if there are other elements that are not working correctly, will help a lot to improve the theme if you can let us know them and provide details and screenshots.
Thank you for your understanding and sorry for this inconvenience!
Thank You Calin.
Even the article has Internal link, External link, Enough words count, Paragraph size, Image alt also, Yoast will show Orange when we create an article or edit an article.
but once we refreshed the page then all the Orange will change to Green.
Hope the above details may help for your developers. It’s easy to replicate or recreate the issue.
Thank You
Giri
Thank you, I mentioned those details to our developers.
With the new update of theme the problems are even more… now I have problem also with paragraphs title… PLEASE, PLEASE, fix asap, a theme like Newspaper can’t be not compatible with Yoast SEO in 2021.
We would like to investigate this issue further. Can you provide more details about your paragraph title issue? Also some screenshots if possible
Hello Vlad,
The reported issue is still there in the new update. I request you to fix the same in next update.
Giri
Hello Team,
It’s surprising that you are not considering this issue to fix yet.
It’s painful to refresh every time to get the green. Hope you will accept that we are waiting so long with patience.
I request you to check with your developers and fix the issue.
Thanks for your understanding
Giri
Hi giriraj,
We are sorry for this, I just checked the last time when this bug was added on our list and this is till there -> https://i.imgur.com/AeWBP6O.png we are a small team with a few developers and those need to do all the new implementations and fix.
I just made a new notice to our developers about this but.
I completely understand the situation Calin.
Hope next release will have the fix.
Thank You for your kind support.
Giri
I’m facing the same problem. Has there ever been a solution for this?
This is the problem is in the process of investigation.
I also have the same problem… what now?
I also have the same problem.
Hello Team,
It seems the above issue has been finally fixed in the Version: 12.2 update. I didn’t face any problems while editing.
Hope it’s fixed by your development team.
Thank you for your follow-up and solve the issue.
Giri
Viewing 18 posts - 26 through 43 (of 43 total)
