TagDiv Composer does not work
I’m Brazilian and I need to customize the Newspaper … Clicking on tag div composer is not possible, how to do it?
Appears in Google Chrome:: “You can not access this site The page https://escoladamulherempreendedora.com/wp-admin/post.php?post_id=2565&td_action=tdc&tdbTemplateType=404&prev_url=%2F%2Fescoladamulherempreendedora.com%2Fwp-admin%2Fedit.php%3Fpost_type%3Dtdb_templates The site may have been moved permanently to a new web address.
ERR_SPDY_PROTOCOL_ERROR”
First I suggest that you check the theme requirements guide carefully
– https://tagdiv.com/newspaper-theme-requirements/
Please note the code provided at the bottom of the guide as well, enter it in the htaccess file then check if the issue is solved – http://prntscr.com/ocfsvl
This code has solved similar issues to the one you are having. Also check the rest of the requirements guide and if needed increase the parameters mentioned in it.
In case you already tried this and the problem remains, we can take a closer look. Send us an email at contact@tagdiv.com and provide admin login, also cPanel if possible. Include a link to this topic in the email. Let us know.
