Please check your ssl implementation. Make sure these 2 links are https (if you have ssl enabled) and they are the same exact url’s: https://www.screencast.com/t/dubXQRnT
If this does not fix the issue, please contact us via email at contact@tagdiv.com and provide wp-admin so we can login and investigate.
Thank you for responding quickly. On your recommendation, I added to the htaccess this code:
<IfModule mod_substitute.c>
SubstituteMaxLineLength 10M
</IfModule>
But unfortunately, in my case, it did not help.
But changing this code to:
LimitRequestBody 99999999999
</IfModule>
everything worked.
Perhaps it will be useful to someone. My site: alextones.com
