tagdiv composer does not works well
Hello team tagdiv,
Taddiv composer does not work well. When I start to re-edit any aliment, raw it showing no style. how can I use it as a live composer? please solve this issue.
I give you both screen shoots link.
1. first screen shoot when i start edit text was yellow
2. second screen shoot when I change the font of email heading
every time I facing this issue.fully puzzled to refreshing on every edit to see what the change I made.
thank you
There seem to be some visual problems with the composer sidebar. What browser are you using? We have tested the composer on Mac and Safari browser and did not encounter any problems similar to those
– https://www.screencast.com/t/gQ4JpQGGqDD
Try disabling browser extensions and clear the browser cache. Also try with a different browser.
Hi Simion !
I posted a request for help concerning the tagDiv composer as well. I have indeed massive visual problems in the sidebar as you describe. I am using Google Chrome for development purposes.
Thanks for your help !
I have same issue IE and Chrome
Using default Chrome browser (latest version) there is no problem
– https://www.screencast.com/t/IwkoRv3Ygv
In Internet explorer and Edge there is no problem as well
– https://www.screencast.com/t/B4owCkV6
I using Mac safari
Be sure to disable any browser extensions and clear the browser cache as well.
We tested on Safari as well, if you want us to test your website, please provide admin login by email at contact@tagdiv.com and we will take a look. In all our tests there was no issue visually with the composer on Safari. Also include a link to this topic in the email.
