TagDiv Composer Editor Not Working (Solution for Cloudways Users)
If you have exhausted all options and the editor is still not working enable “DIRECT PHP FILES ACCESS” (under application settings). This solved my problem with the editor but I am not happy I need to enable this for security reasons. So I suggest to enable it when you want to edit with the composer and disable it when finished.
Thank you for those details.
Have a nice day!
