So you are entering content in the column text and it is not saved? The content should be saved after you enter it and close the window
– https://www.screencast.com/t/myB6kzkrg
Then save the whole page and that would be all.
This could be related to insufficient memory or other resources
– https://forum.tagdiv.com/newsmag-requirements-for-newsmag/
Check the guide carefully and make modifications where needed. Contact your hosting provider for assistance if necessary.
After you adjust the parameters, check if the issue is still happening. If it does, try as a quick test to deactivate all non-theme plugins, then check again.
Let us know the result.
Hi there,
Please check this screenshots from “System status”
It still not working, Any ideas?
Hello aeshlog,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to your setup page. Provide the full FTP access and CPanel. Before this, ensure that you are using the latest version of the theme or if not, please update it via FTP way.
