TAGDIV Composer Help
Hi guys, your switch from vc to tagdiv is a big headache for me, i did not only use vc for my front page, i even used it for some core profiles, over 60 profiles. with an already saved template. for an event i have two months away. I have very little time to spend changing it, and first of all the tagdiv composer is not as simple to use, and i do understand its in its early staged.
But i will kindly ask if there is a way a team member or your organisation can fix my profiles for me, i dont even mind paying a little, but currently, my profile pages are messed up in arrangement. all linked from here http://www.accrafashionweek.org/2017designers at a point where clients are visiting.
They can’t fix your content.
You can keep using Visual Composer — you don’t need to stop using it. TDC is optional, and is primarily for those starting with theme first time, or who only use it for stuff like home page and custom pages — not posts.
If you use to use TDC in place of VC, you will need to redo some stuff.
Or, just keep using VC.
Thanks but my front page goes offline when I switch off td composer. It says
wp booster error:
td_api_base::mark_used_on_page : a component with the ID: tdc_state is not set.
/home/accrafashionwk/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_api.php
wp booster error:
Missing parameter: ‘file’
/home/accrafashionwk/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_autoload_classes.php
Any solutions?
Unfortunately this is a problem in the latest update. Please use the fix mentioned here:
https://forum.tagdiv.com/topic/problem-after-update-3/#post-187032
