TagDiv Composer Images Side By Side Mobile Viewport
Hi there,
I am trying to create a 3×4 grid of images via TagDiv Composer, where on mobile 3 of the images are next to each other, (so it’s a 4×3 grid on mobile). I’ve tried this with having just 1 column in a row and adding an image box with 4 images in it and also I’ve tried adding 4 separate columns in a row with single images. All viewports seem to work as expected, but on mobile the images are always on top of each other.
I cannot seem to get the mobile viewport to show images next to each other, even though I’ve selected the row layout across all viewports as 1/4 1/4 1/4 1/4. I also tried 1/3 1/3 1/3 for mobile, but it reverted the other viewports to that and still showed images on top of each other.
I’ve tried to click the mobile viewport and change the width of the images, but with no success either.
Does TagDiv Composer allow images to be next to each other on mobile? If so, can you take me through the steps please…
Many thanks
Hello !
Unfortunately that is not possible, maybe with very small pictures. if you would do that you will receive google errors because the images will be too small for the user with smaller devices to have a good experience on your website.
