TagDiv Composer Installation problem
Hey, I am trying to update the newspaper basic theme demo in my wordpress website but when am trying to install some plugins like TagDiv & social icons, Its showing it does not have proper header. Kindly resolve the issue since its giving messed up website preview with rows & column html codes on the home page.
The result shows this information-
Installing Plugin: tagDiv Composer
The plugin does not have a valid header.
Downloading installation package from https://indiangroom.in/wp-content/themes/Newspaper/includes/plugins/td-composer.zip?uid=5cb21ce4ea917…
Download failed. cURL error 60: SSL: no alternative certificate subject name matches target host name ‘indiangroom.in’
Return to tagDiv plugins panel
This issue happens in particular cases and is tied to a specific server and PHP configuration. There are a few steps in solving this issue, however.
1. Check file permissions: http://www.wpbeginner.com/beginners-guide/how-to-fix-file-and-folder-permissions-error-in-wordpress/
2. change PHP version on your host and check security modules.
3. comment out the check for the error from the WordPress code:
https://scotty-t.com/2011/03/28/fix-for-the-plugin-does-not-have-a-valid-header/
4. Install the plugins via FTP: http://www.wpbeginner.com/beginners-guide/how-to-manually-update-wordpress-plugins-via-ftp/
