TagDiv Composer Not Working After SSL Issue
Hi everyone,
I’m currently facing an issue with my website hosted on GoDaddy. I’m using the Newspaper template by TagDiv, and everything was working perfectly until a few months ago. Back then, I used a plugin to generate my SSL certificate, but I forgot to renew it. I’ve now fixed the SSL issue, and the certificate is properly configured, but I can’t use the TagDiv Composer to edit or create any blocks.
I have experience working with the TagDiv Composer, and this issue only started after the SSL problem. I’ve tried clearing the cache, disabling plugins, and checking for updates, but nothing has worked so far.
Has anyone else encountered a similar problem? I’d really appreciate any guidance on how to resolve this.
Thanks in advance!
View post on imgur.com
Check this topic: https://forum.tagdiv.com/topic/tagdiv-composer-editor-not-working/
I hope that helps you!
Amazing!
Problem solved. Thanks
