I run a recipe blog that relies heavily on post layouts made with WP Bakery Visual Composer and an add-on for displaying recipes. My only complain with TagDiv Composer is that it will not allow me to display my images correctly on posts using WP Bakery Visual Composer’s “Single Image” module.
If I de-activate WP Bakery Visual Composer, TagDiv Composer doesn’t seem to work on Posts; only Pages.
How can I:
A) stop TagDiv Composer from giving me weird image display sizes/cropping on Posts
or
B) use TagDiv Composer on Posts and not just on Pages?
If you use vc on posts, then unfortunately you will not be able to use our tagdiv composer as it will not work on posts and it will conflict with wpbakery page builder with some elements especially images. In this case you should continue using tagdiv composer or remove all VC elements from your posts and use the tagdiv composer. Do not use both at the same time.
