tagDiv composer problem
Hi. I’ve just bought the theme today.
I want to edit an imported homepage with the tagDiv composer, but when I click the button it displays a grey page with the message “Situl se confruntă cu dificultăți tehnice. Pentru instrucțiuni, te rog verifică emailurile primite de administratorul sitului.”
The hosting provider says they cannot modify the required parameters (max_execution_time, suhosin.post.max_vars, suhosin.request.max_vars).
Which one of these parameteres triggers that error? Maybe I can negociate with the hosting provider.
Is there no other option than to buy a more expensive hosting package or move everything to another provider?
  • This topic was modified 7 years by ooooooof.
Hello !
You need to make sure that you do meet the theme’s requirements wich can be found here: https://tagdiv.com/newspaper-theme-requirements/. To make sure that you meet them you can check it in Newspaper – System Status like here: https://www.screencast.com/t/ntdDqdnA2sW
Also if you do have access to your cpanel you can edi the files by yourself. You just need to take a look on the newspaper documentation and make the changes as shown there. Take a look at this tutorial: https://www.youtube.com/watch?v=WmlGHje1V50
