When I set up the homepage for our federation. No problems at all.
But ever since I tried to return to the page, I only get the spinning wheel of death.
Minimum Requiremens are met.
I have disabled all plug ins twice but it did not work then either.
What can I do?
Hello Grex,
Ensure that your system status parameters and increased according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ If you are using some untested plugins, try to disable all of them, leave just our required plugins to be active, clear all the caches and check the results.
For more information about our page builder, please check here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/ -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
