tagDiv Composer Problem
Installing Plugin: tagDiv Composer
The plugin does not have a valid header.
Downloading installation package from https://?????????.com/wp-content/themes/Newsmag/includes/plugins/td-composer.zip…
Unpacking the package…
The package could not be installed. PCLZIP_ERR_BAD_FORMAT (-10) : Unable to find End of Central Dir Record signature
Hello joes,
From cert’ain errors the plugin folder was not right removed and installed and that’s why you bring this warning, sorry! you should log in to your FTP and remove again the plugin and re-upload it via FTP way on the server, clear all the caches and check the results. It should work as expected.
