Hello, I have been using Newspaper for 2 years now, and since a few days, the TDComposer no longer works, it does not load a new page, neither the existing pages, it is always loading and does not open the page. In articles, I can no longer choose, after creating the post, a different template. I have made all the changes as required by the requirements.
I have already read several posts with the same problem, I have made all the changes required.
the site in view is seen perfectly, but now I can not change anything.
Please help me.
Thank you
Please try to increase more the wp-memory_limit, also please add this code in .htaccess
https://www.screencast.com/t/ZvHNhdQI
If the problem persist please deactivate all plugins that are non theme clear all cache and try again.
Re-enable the plugins one at a time and tried to edit a page, the problem seems to be the “WP Statistics” plugin. By enabling it the page is not opened, while disabling the plugin, everything is back in place.
I leave this plugin disabled for the moment, even if having the visit statistics is important.
Thank you
