I use a row on my homepage with two colums: 7/12 + 5/12 Created in Visual Composer. (My website: http://airportal.hu/ – see the top part of the page)
When I install & switch on Tagdiv Composer that part of the page appears in one column (1/1).
I’d use Tagdiv Composer because it’s nice plugin, but because of thes problem I had to get rid of it.
Would you fix this maybe in the next releases?
Thanks,
Adam
You will not be able to use the layout created initially in visual composer. If you create a page in one page builder, stick to that page builder. If you want to change page builders, you have to re-create pages with that page builder. tagdiv composer does not recognize visual composer elements and vice-versa.
