TagDiv Composer… Problems
Hi friends, I am having problems with the use of the Tag Div Composer.
When i use different “Blocks”, they do not respond in the way that is supposedly predetermined.
For example: they do not occupy 100% of the width.
I also need to use ways to use Big Grids with titles outside of the photo (or imagen) or that adapt better in Mobile and I have no way.
Please help.
I send attachments as I have my Blocks … (so they can see that they do not work out the way they should).
Att1 – Block1: http://lasopapa.com/wp-content/uploads/2018/01/Block1.jpg
Att2 – Block6: http://lasopapa.com/wp-content/uploads/2018/01/Block6.jpg
Att3 – Block13: http://lasopapa.com/wp-content/uploads/2018/01/Block13.jpg
Hello Mariano Jonte,
Unfortunately, I cannot access your screenshots. To be sure, try to disable all of the untested plugins, clear all the caches and check the results. Also, purge all CDN files if you are using Cloudflare system.
Thank you Catalin, my site is http://www.lasopapa.com
Link: http://www.lasopapa.com
I’m sure there’s access, maybe at the time you checked in there was a problem.
Images problems:
Block 1
Block 6
Block 13
Hello Jonte,
Does not work, sorry! Please create them again because the page is not working. I suggest you using the Jing online tool.
Ok there I uploaded the images to an external server.
Please see…
1º) Block1 : Empty space in the right.
Image:
https://image.ibb.co/ekF2Kw/Block_1_Empty_Space.jpg
https://ibb.co/bvVrCG
Why is a space left blank?
2º) Block2:
A “more” note appears on the side, alone. Because it does not occupy 100% of the width with the Block2 format ?.
Image:
https://image.ibb.co/czXSmb/Block_2_Error_Visual.jpg
https://ibb.co/cOgL6b
3º) Block3: Again, a note “ghost. The block does not occupy the entire width.
Image:
https://image.ibb.co/g7DYRb/Block_3_Error_Visual.jpg
https://ibb.co/ccArCG
4º) Block 4: Again.
Image:
https://image.ibb.co/bW47mb/Block_4_Error_Visual.jpg
https://ibb.co/fVGysG
5º) Again… right and down…
Images:
https://image.ibb.co/gnEUzw/Block_5_Error_Visual.jpg
https://ibb.co/cBBWCG
Please, help, the blocks are not shown as they should be.
I put some of the blocks as an example, but the same thing happens with all of them.
Thank you, regrats.
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this topic so we can quickly identify you.
Thank you, send the email with the data. regards
