I frequently run into the issue that our Single Post template can’t be loaded in the TagDiv Composer tool due to the ‘Single Post Content’ block. When trying to load the template, it keeps on loading indefinitely.
I showcase the issue in a video here: https://www.youtube.com/watch?v=sXIOKpp2a8Q
Newspaper version: 12.6.5
Wordpress version: 6.5
Let me know if I can provide any more information to help resolve this issue.
Kind regards,
Jan.
This topic was modified 2 years by
juniordiscart.
In case the console log might be of use, you can find it here: https://pastebin.com/ywF7DNBu
I think it’s related to one of our plugins again. Disabling all plugins except those of TagDiv makes it work again. I’ll report back which plugin was the culprit.
Thank you for your response. It looks like it was the AIO SEO plugin that was causing the issues. Disabling it made the Tagdiv Composer work again as expected.
Kind regards,
Jan.
Hi Anamaria
I can provide access, though I have already cleaned up the conflicting plugin and its settings. The issue I posted above is not entirely reproducible any longer. When I install and activate the plugin now, the small reproduction scenario I had in my YouTube video loads the composer correctly. So perhaps it was related to a specific setting in the AIO SEO plugin.
However, my single post cloud template still breaks and fails to load (when the AIO SEO plugin is active) with the following message:
Error at zones: 6(models) : 5(dom). The model does not match the content Current state has involved an issue.
If you’re still interested in investigating that issue, I’m happy to provide admin access.
Kind regards,
Jan.
