Tagdiv composer size problem
hello, when I want to edit my page with tagdiv composer, it appears in a small form on the side. I deleted the plugin and reinstalled it, it didn’t fix it. I tried different browsers and the result is still the same. How can I fix ?
problem screenshot : https://ibb.co/GJTps6t
Hi tracertt, usually this kind of problem it appears when you are using untested plugins. Please make a test using only tagDiv plugins and see if the problem persist.
Let me know the results!
