TagDiv Composer Text Block PROBLEMS TO EDIT
This is the problem. Where is the SAVE button?
When I put the text, nothing showing.
I have inspected the text element, I do not see any problems with it. Simply insert the text in the editor area, and close the window
https://www.screencast.com/t/wIDXVaCr7YE
https://www.screencast.com/t/TlJX68sl
The content will remain in the element as entered. Then save the page and view it. If you have problems achieving this, please follow this guide and make modifications to the parameters mentioned in this guide if necessary
https://forum.tagdiv.com/system-status-parameters-guide/
This might be the cause for the issue.
