tagdiv composer will clear woocommerce product shortcode
Hi.
I found that using tagDiv Composer to edit the page deletes the WooCommerce short code inserted in other editors.
How is this going?
  • This topic was modified 8 years by fanjumin.
Hello fanjumin,
Please provide more details about what exactly you have done and how did you add the Wocommerce shortcodes.
Hi.
tagDiv Composer with WooCommerce and Virual Composer has compatibility issues.
Please see:
Step 1:Create a new page using tagDiv Composer,Or edit the old page.add Row,extra class:’Woocommerce_Product’.Save the page and return to text mode.
https://prnt.sc/i4vy7p
Step 2:Insert WooCommerce Product shortcodes in text mode,Then save the page and go to WooCommerce Set interface,
https://prnt.sc/i4vozs
Step 3: The just edited page is set as the shop page.
https://prnt.sc/i4w08j
Step 4:This page can be accessed normally as a WooCommerce default page.
However, when returning to tag Composer to continue editing, it prompts for an error.
https://prnt.sc/i4w1en
Another serious problem is that if you set the page as a WooCommerce store page, edit the page again using tagDiv Composer.
a) If you do not edit this line, WooCommerce Product shortcode will also be displayed.
https://prnt.sc/i4w66g
b) If you do anything about this row
https://prnt.sc/i4w6u8
c) WooCommerce Product shortcode has disappeared.
https://prnt.sc/i4w85o
Hello fanjumin,
Do not create more topics with the same problem The answer to this topic has been replied here -> https://forum.tagdiv.com/topic/tagdiv-composer-with-woocommerce-and-virual-composer-has-compatibility-issues/
