TagDiv Composer won’t work and have a license issue
I recently noticed that Newspaper no longer recognizes my license. The dashboard shows that the theme is not registered, even though the license was correctly activated before. How can I fix this issue?
Normally the theme doesn’t deactivate by itself. If it was activated with the license key before, and it was not reset manually, then it should have remained active.
Please try to activate it again. Or is there an issue when you try it? If there is an issue, I will take a look as well. Please send an email at contact@tagdiv.com and provide a link to the website and admin login (user and pass), and also the license key. I’ll check as soon as possible.
