Hi there. Today appears this error in my home page. I remove all and start to build again and the error appears again and again.
This is the error:
Errors at columns elements: 2(models) : 1(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
I don´t know what to do, please could you help me? many thanks
You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
Hi Vlad, thanks for your support!
At least, the plugin that was causing the error was RevSlider. I put it again as a shortcode with a TextTitle Tagdvid element and fixed. It works fine
The web is: http://www.villadeiscar.es/nuevaweb
Many thanks sir!
