Tagdiv Instagram Problem
I integrated the Instagram plugin into my sidebar and footer. The images appear well but the last one is dated August 21, 2019.
I have posted a lot of them since then but the update is not done. What is the problem with that?
https://rsandlowb-ride.fr/agenda/
From what I know there was some changes in Instagram roles so you’ll need a token access from Instagram to can show that Instagram feeds; there will be a new implementation in our Instagram widget in the coming update that we hope will solve this problem, meanwhile you’ll need to find a plugin that can display Instagram feeds.
Sorry for the inconvenience!
