TagDiv not working with LearnDash Focus Mode
I am using the LearnDash LMS and their support team figured out that the Focused mode is not working with the TagDiv Composer. They said to contact you about disabling tagDiv on Focused pages and said this:
“They seem to force their settings on any registered custom post type. I would inquire with their support as to how to disable for certain post types. If they have any guidance as to how to disable their functionality on custom post types, we can maybe help adjust any code they provide to be LearnDash-specific. There really should be some way to disable functionality on certain pages if they’re going to force layouts (that break things) on all single posts on the site.”
Later, they said,
“I’d inquire with them as to how to disable their functionality on certain post types. Like a code sample or something. From there, we may be able to help tailor their code sample to LearnDash.”
What should I do?
Unfortunately we didn’t tested the LearnDash Focus Mode plugin with our theme, therefore we can not say for sure if this will work correctly with our theme or not, sorry!! Also, we cannot provide support for untested plugins.
This is our list with tested plugins with our theme -> https://www.screencast.com/t/cmPkh9jba4sZ
Also now the tagDiv Composer contain all the theme functionality, you can check more about this here-> https://tagdiv.com/updating-the-core-of-tagdiv-themes/ also the tagDiv Composer can not be disable on certain posts or pages.
