We will write all the new features and all the fixes in the changelog: https://tagdiv.com/newspaper/
Thank you for understanding!
The question is when, because the list of WooCommerce product categories and tags is very important. Therefore, such a shortcode should have a very high priority.
I’m waiting a year, so I’d like to know the date when it will appear and you will be able to use and create a shop on tagdiv Shop.
And did you report it? Or just for a break as you always write.
Is there somewhere where you can submit tickets and problems to solve?
Yes, I reported again. The problems and the bugs are discussed on the forum.
A simple workaround for the category list is to create a menu in Appearance -> Menus: https://prnt.sc/w1MrA8C8U3-R and add the product categories there. Anywhere you can add a menu in Composer is by using the list menu element, for example.
I understand your desire to help, but this does not justify the lack of shortcode for WooCommerce widgets.
It’s like someone told me you can ride a bike instead of a car. Both vehicles will reach their destination, but it’s not the same.
Besides, your solution is probably not styled with css and would have to be modified and adapted. Unless you show me a solution that will work, is styled css in your template and works properly.
I would like to go back to filtering attributes with Woo Attribute Filters.
2. Woo Attribute Filters – set the order
How to set the order of filters and move categories to the top and others to the bottom?
Because your suggestion below doesn’t work.
1. You can’t drag and drop because there is only one element there. You can write them in another order; this is what I meant.
I added 3 different filters as suggested to set the order. So I copied the shortcode 3 times.
this setting causes that all attribute filters are counted separately and should only be displayed on top above the attributes.
https://ibb.co/JybF8XQ
So you can’t duplicate the Woo Attribute Filters shortcode because then each one is counted separately.
How do I set the filtering order?
Well, that’s another lack of basic functionality. How can the store lack the ability to set the order of filters?
This is another point that should be entered in red for urgent improvement.
How are we supposed to create a shop on TagDiv Shop? Nothing works here and there are no basics.
Please don’t joke. I’ve been trying to make a shop on Tagdiv Shop for a year.
Unfortunately, you haven’t been able to do basic functionalities for a year, to no avail. Tragedy.
This project is not progressing.
This reply was modified 3 years by
creativeopole.
Hello, how to solve the problem with the menu on mobile devices?
1. Changing the background of the image in the menu on the mobile device
2. Changing the navigation color after hovering over the inscription
Hi creativeopole,
I’m sorry that you can’t create the shop you want with our theme. For the moment on the shop side, our theme can only create shops similar to our demos: – https://i.imgur.com/2Q9ugSI.jpg if it’s an option on one of these demos you need, then it’s in the theme, if the demos don’t have the option you want, then it doesn’t exist in the theme.
1. The background image can be changed for the mobile menu from the theme panel – https://i.imgur.com/yVwO7f0.png
2. The mobile menu elements can be adjusted using the settings from the theme panel – https://i.imgur.com/JCUsXnG.png
