[tagDiv] Slide problem
Hi, I’ve been using [tagDiv] Slide in a sidebar on Newspaper, with images from 5 posts which up to now been scrolling horizontally with no problem. Today I noticed that all 5 images were showing, cascading vertically, and appearing over/under other content. I’ve ‘fixed’ the issue temporarily by only selection only one post in the slider. Could you give me any advice/help?
Many thanks, Ian.
Now that is unusual, the posts should be displayed in the slider, just like the element is displayed in the live theme demo
– https://demo.tagdiv.com/newspaper/ios-slider/
If the slide is not displaying like that, then something is not functioning properly.
It could be affected by a plugin, please try to deactivate all plugins except theme plugins and clear all caching installed. Check if this has any effect. Also try placing the slide on a new page and check the results. Let us know.
