tagDiv speed booster 2.5, problem in RTL
My site is RTL without tagDiv speed booster 2.5 , the main menu is ok !
http://prntscr.com/43sstp
but with tagDiv speed booster 2.5 :
http://prntscr.com/43stym
plz fix the problem with tagDiv speed booster 2.5 activated in main menu direction , i need to be on the right position like on the first snap .
there is other problem on the font of rtl , it goes to default with tagDiv speed booster 2.5
my site is http://www.twojaws.com/
but i will not use tagDiv speed booster 2.5 @ my site untill you help me to fix it > thank you .
hi,
thank you for reporting this issue, we will take a look.
I also see that your site looks very different from the main theme.
I’m guessing that speed booster changes the loading order of css (all the css that your site is ussing).
Thanks for you message.
Radu A.
but i didn’t do any change to the orginal files all changes i made by VC or in theme options only .
the problem shown in very style even on the default style but only in RTL .
  • This reply was modified 12 years by iha.
Try this custom CSS, add it in Theme Panel > Custom CSS:
.sf-menu {
float: right !important;
#td-top-search {
right: auto !important;
left: 40px !important;
Thanks for the message
